muss
Hi Guys
I run a setup in my car consisting of all fusion gear, two subs two amps rears and front components all coming off a pioneer HU (cant remember model but it is a 2009-10 rear usb 3 rca one) now i had this all running like a dream for weeks but the rears were coming off the hu instead of the amp so when i finally had time i ran the wires plus and extra set of rcas and hooked these up to the amp as well.
Now what happens is after running the car for 10 minutes or so i start to get an alt whine in my fronts that gets progressively louder until im forced to shut everything down, after leaving for a while i can start up and get another 5 - 10 mins before this happens.
I have been though every trouble shooting step i can think of and i can confidently say i have narrowed it down to the HU. i.e. tried new rcas, moved them etc ran mp3 player directly through amps with no problem so i re grounded the HU directly to the battery and re-wired everything else back there as tidy as possible but still no luck.
After a LOT of googling on the subject I can't find anything quite like this. I suspected a blown pico fuse so i tried the ghetto wire fix to no avail and even pulled it to bits and hard soldered the fuse but everything is still the same, works for 10 minutes brilliantly then the noise comes on. I haven't been able to find any posts on a noise issue that is delayed like this....
Anyway I dont have another HU to test this for sure so I am about to go and spend $200 on a downgrade to fix the problem.
Has anyone heard of symptoms like this before? is my HU given up the ghost or am i missing something???
