Engine whine issue.
Update:
So, after rerouting the cables (power cable down one side and RCAs down the center console) I have successfully eliminated engine whine.
In the 2015 Toyota GT86 (Scion FRS in the US), there are in fact supplemental factory power cables running down the sides of the car, which were probably contributing to the whine.
I purchased the following shielded cable to help with any other interference.
Thanks for all of your expertise and wish you all the best in your car audio adventures! It's been a truly helpful forum.
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door seals. I try to Avoid that area with RCAs,and most speaker wiring from the amp. Its usually just fine for power and remote wiring. Ive had no issues with using Stinger Zero Noise RCAs so far
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
You need to troubleshoot. I assume you have an aftermarket HU. I'd start there by running a signal from a phone or ipod (etc) to the RCA outputs...
5
RussellJ
CarAudio.com Newbie
RussellJ
Dubai
audiobaun
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
