Engine noise..
  • 1
anders1127
So I just installed a Soundstream Dtr4.500 and wired only two channels so far to two tweeters and two horns, I'm running the signal from my mono amp which gets it's signal from a Stinger Line out converter, I've grounded all places possible, changed the RCA's to straight to the line out and there's still the whining noise. The sub has never had any distortion like this, probably since the low pass doesn't pick it up. I also even bought into the "ground loop isolator" by Stinger, but the problem is still there just as badly. What should I do?
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
anders1127
anders1127
United States
anders1127
maylar
    Jun 2, 2024
    Jun 1, 2024
