Engine whine and ground loop fixes... take two
guys can u help me please.. im ready to pull my hair out.. im getting alt whine and cracking and popping. It only seems to happen when i turn it up loud, then its present and will stop whenever it wants it seems. ive grounded my rca's ,relocated head unit ground, tried isolators, nothing cures it.. i followed steps on noise prevention site i found, and from that it points to ground loop.. i have two diamond audio 15" D9's , 4 d6 components, hifonics brutus 2000d, da d6 4chan amp.. this system will crack your jaw when operating correct.. please help
I have a slight whine in my front stage, only really noticeable when MY HU is on 0. It makes a "pop" sound when I turn my HU to 0, and when the HU shut's off. Also get a crackle exactly like 2muchbass4u2tak's issue at higher volumes. I grounded my RCA's, but did nothing. My sub has no whine, but I did hook it up to another amp and it had a crackle in it, but went back to original amp and no noise still. I noticed in the OP's picture that he grounded the speaker and sub rca's separate, that shouldn't make a difference if you ground them together should it?
yep. I redid all of my connections today made it look nice. and the **** engine way got MUCH worse. its pretty loud now. doesn't make any sense. everything is back in my car the same way except the grounds are shorter.. I could only assume that my rcas are not grounded properly. going to try this tonight. will update this weekend
My best advice is if you have tried all of the other steps, run a dedicated ground wire and test if that is the issue. You don't have to run it through the car. Just run a temp wire outside the car from your amps to the front battery or the engine block. This is advice I was given when I had engine whine that could not be traced and it worked for me. I since have ran that dedicated ground permanently.
i ust upgraded my rca cables to knu conceptz highest quality 4 channel cable.
I had some really bad engine whine, and luckily for me it is COMPLETELY gone now...
best 30$ ive spent on my system yet, well worth the money.
Wow,this thread may solve at least part of my issue. I was hooking up a new sub to my amp,accidentally touched the wires together(yes,I was stupid and didn't shut the stereo off in all my excitement) and got the immense whining noise.
I also have a beeping noise(possibly a door chime,not sure yet) and I'll be trying this tomorrow.
Great thread!!!
I can officially cast my vote as to how well this works. I simply did as shown in the illustrations and it cured the mistake I had made when I grounded my wires for my sub on accident,which blew the internal grounds.
Just finished up about fifteen minutes ago with 100% success! NO NOISE!!!
i had problems with my sub hitting off que and i narrowed it down to the hu (pioneer p80mp) took it to repair shop and it was the sub pre out ground fuse. sounded great after. now i'm getting alternator whining through my left front and rear speakers when it set the hu on auxiliary. i called them and they told me to check and make sure there were no exposed wire anywhere behind the hu. they said this is the only reason this would happen. have yet to check.
btw i'm just running components off my hu. no amps, except for hu pre amp.
my pioneer still has this wretched noise.
I wanna burn it.
I also have my **** grounded, so we'll give it another go on the amp end of things.
Probably already been answered but what gauge of wire should be used to re-ground the head unit? I want to re-ground it to the battery in my trunk, probably 15 feet, is 18 gauge enough or would like 16, 14, something be necessary at that length?
Also, is it better to ground from the chassis of the head unit to the battery or from the ground wire out of the harness to the battery?
I re-grounded my stereo with 16 gauge wire from the battery to the chassis of the stereo, still get a hum when the car is off. Have yet to check what it sounds like when the car is on.
This little nugget save me alot of money. if only I had found this thread before i spent hours grounding and re-grounding. it worked like a charm. Thanx!
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
JohnPD
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
