Engine whine and ground loop fixes... take two
I have opened up my DEH-P5900iB headunit, but am unable to locate even a single fuse... I cannot find any tags labeled with FU-???I am lost, I would be able to fix this headunit if only I knew where the dang fuse was... any help on this model would be appreciated
take some pics and then we can help
Ok, i bought the service manual for $10 online, I found the fuse, it's on the underside of the circuit board... go figure. Wasn't incredibly hard to disassemble the entire thing, just tedious.
Well, I soldered on a 1-ohm 1/4 watt resistor in place of the pico-fuse, hooked the HU back up in my car and still recieved the god awful engine whine...
I'm almost positive I took off the correct fuse... it had a little "p" on it and was labeled FU-352.
Is it because I used a wrong type of resistor? it seems like it should be fine...
I'm opening it back up right now, I'll take some pictures and upload them.
pics of the back side of the motherboard, with a 1ohm 1/4 watt resistor soldered onto where the fuse used to be.
Still receiving awful noise.
I have the RCA cables grounded right now instead, because the RCA grounding works well as a temp fix. It reduces the noise by about 90%, but I'm really just not satisfied... I want that fuse fixed for good, but the resistor isn't doing a ****ed thing. Any help/comments would be helpful
Thanks guys
Pics:
http://i35.photobucket.com/albums/d172/southbark33/IMG_1988.jpg
http://i35.photobucket.com/albums/d172/southbark33/IMG_1989.jpg
http://i35.photobucket.com/albums/d172/southbark33/IMG_1994.jpg
I also have the service manual if anyone wants a look at it for the DEH-P5900iB model
If it'll help you diagnose my problem then I'm more than happy to share it, hit me with a pm
Well i could tell you a way that you could check to see if the fuse is any good,but now that you replaced the pioneer fuse with resistor it won't work. My guess is that the fuse is still good since you were getting signal to the amp. If that fuse was blown, you would get no sound. My only suggestion is to check all of your grounds and make sure that they are good.
EDIT: make sure you did change the correct fuse. It should have been no bigger then a grain of rice and been very hard to see with out a magnifying glass.
are you referring to the Pioneer HU's?
The Pioneer HU's have an external fuse, it's easily visible, birght red 10amp fuse that prevents too much power from passing thru the headunit, a safety feature. However, the fuse that I and most other people are talking about is the pico-fuse inside of the HU on the backside of the circuitboard. This fuse is what grounds the RCA preouts internally. If that internal pico fuse blows, you recieve overpowering engine whine, which is what I'm getting right now. I was searching through another forum with the same topic and they said that they fixed it removing the blown pico fuse and replacing it with a 1ohm 1/4 watt resistor, which is what most HU's have instead of a fuse.
I tried that method and it didn't work for me. I tested the connection between the pico fuse prior to taking it off and it wasn't giving me a reading.
Yes I def changed the correct one, I was referencing the schematics and the fuse was about the size of an eyelash with a little letter "p" on it, with the tag "FU-352" next to it.
Wow great sticky. After reading all the pages i fix my stupid wineing noise also. Been messing around with the system 3 days and after reading this and doing the ground the rca's it finally fix it.
Thank you very much everyone for the tips.
So how do you guys ground the rcas when the outputs arent right on the back of the headunit? :Like my RCA outputs off my pioneer have 8" cables so the connections isnt right on the back of the deck, how would you ground them still?
so when i accelerate on the road, my engine whine increases, its especially bad while listening to the radio. for the most part, my music drowns out the whine when playing a cd
is this a typical alternator problem or Pioneer head unit, since thats what im running?
thx
Just installed a p600ub yesterday and at low volumes it was making noise. I ran a ground directly from the battery to the head unit and it made no difference at all. Wrapped some 20g wire around the rear outputs and noise completely gone. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
this whine problem just happend to me. i have a clarion h/u grounding rcas only makes it louder my system has been the same for almost 2 years,it just started after i started my car one morning
Thats because the grounding issue is a loop contained within the head unit itself.
Anyone ever have a problem using two ground loop isolators on same vehicle? I installed one between my iPhone and my AUX in on the back of my headunit and then another one between my SUB OUT and my Input on my amp. When both are hooked up I get the same engine whine with really bad feedback through my subs that wasn't there before the isolators. But with just the one for my AUX in hooked up, there is no more engine whine. What is causing this?
okay, picked up a 780mp, i love the 880prs, but i love the look of the 880prs. well the 780mp had the horrible alt whine, so decided to do the rca ground trick.
had some remote wire, so i cut 6 pieces, put one in each rca, then tied all them together. then grabbed some kicker 16 gauge, found a screw on the headunit chassis. took of the screw, put the wire, tied everything together, wrapped it in electrical tape. and presto, **** is gone, its still there, but only 1%.
I have an eclipse cd7000 and i have horrible engine noise. I put ground isolators on my preouts for my front and rear rca cables and they didnt help. I tried grounding them to my head unit and it didnt help. can anyone tell me where i can ground my headunit? In my 2001 bonneville, there is no metal behind the radio. Also, should i try to ground my rca cables at the amp as well? Could a bad amp ground cause this problem so badly?
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
3K
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
JohnPD
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
