Eq help!!
  • 2
rm2406
LA
hello all, ive installed an eq and i have a question... the eq has 2 inputs. aux and cd. which one is best to connect rca's to? also both inputs have rca gain control. my stereo is kenwood with 2.0v pre out. so where do i tune the rca gain input to? also my amp has 6v to .02mv where should that be also? thank you very much //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it an phonics digital.. it has rca left and right gain inputs. should i turn them all the way up, down, or put in middle?
537
554
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
631
rm2406
rm2406
LA
rm2406
Decebal
    Jun 10, 2024
