Is it bad to be under RMS?
You will be fine at 75watts x 4. The main reason we over power is to create 'head room' so you don't clip trying to make a particular am do more than it's designed to provide.
Is it bad to go under RMS on component speakers?seeing that the polk Audio DB6501 need 100 watts rms at 4 ohms and most 4 channel amps at most give 75 at 4 ohms
If you want a closer match, GMD8604....100rms@4ohm.
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
dkking
dkking
Riverton, Ut
CSCStang
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
