External port tubes?
  • 4
Mooncatt
CarAudio.com Recruit
65
6
When I was originally in to car audio, ported boxes all had the tubes inside the box. I've been getting back into the hobby and have noticed a lot of boxes now have the port tubes extend outside the box. Is there a performance gain by doing this, or just a personal preference?
All the ones ive seen like you describe look that way cause the box is way too small to fit all the port length. Aside from that, i dont know if there is a benefit per se.
That makes sense. I've always preferred sealed boxes in the past, so never dived into ported construction. In the past, ported boxes always seemed require more volume than sealed, making it a non-issue to fit the tube.
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
800
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
981
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
957
Mooncatt
Mooncatt
Boomin_tahoe
