Extremely low voltage
Is the voltage any better if you have the headlights on? Like Martin said you might be experiencing what Keep Hope Alive was.
Wow. I turned on my HVAC system one click on the lowest setting and my voltage jumped up to around 13.5 for a majority of the time. Before it would be at 11.6-11.8 if I'm driving under 45mph but once I go past 45mph for some reason it goes up.
I'm assuming a high output alt will help keep my voltage high and steady with no negative affects on the car correct?
before you get that ALT try an external voltage regulator. Your Car's PCM may be controlling the voltage and keeping it maxed out at 12v. *****(When you bypass the internal or take it out all together the battery light will come on. this is OK.)*****
Id rather be safe anyway. I have around 2500 watts with just an optima yellow top under my hood and big 3 with 0 gauge. My under drive pulleys don't help either lol so I'd rather get a beefy alternator
This is my thought. Even if you go with a HO alternator (which is a good idea) an outboard regulator is a good move.
339
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
540
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
4K
RoYALbLUE08
RoYALbLUE08
NYC
RoYALbLUE08
Brendon Jenness
    May 8, 2024
    May 8, 2024
