F-150 Electrical Problem PLEASE HELP
  • 2
camdogg4570
I have a 1997 F-150. a couple months ago I installed a new 130 amp alternator, the stock alt was a 95 amp. I haven't had any problems or issues with it. It also has an AP-15001d amp powering a Power Acoustik MOFO X2 15, with 4 gauge power and ground wire. I do not have the big 3 or any other upgraded electrical wiring.
So this is what happened, I was driving to work at 55 mph for about 6 miles with the heater on. My radio was also on but I was not bumping any bass. The bass knob was almost completely off. Then getting onto the interstate the head lights either went off or dimmed very badly, I could not tell, I also couldn't see any gauges on my dash. The radio "turned off" but it began to beep. I was traveling at 70 mph (about 2000 rpm) for about 3 miles. Then when I exited off the interstate right when I let off the gas everything turned back on, headlights, radio ect... When I arrived at work I turned the truck off and turned it back on and everything seemed to be working properly. I unplugged the amp after that. after work I went home a different way so I didn't get on the interstate and drove 55 mph and everything was fine. All of the gauges worked as they should.
If you have any idea to what could have caused this, or have any idea of what I should check/test please let me know.
Thanks
take it somewhere with a higher function scanner, not like the obd2 you can buy everywhere. a genesis or snap-on/mac/etc should do. have it checked for events/codes. may show a power loss to the bcm (which happens to be your instrument cluster) possibly it may have found a fault, and disabled whatever circuit caused the fault, likely related to trans. does not always show the "check engine" mil when it happens. other than that, you can check power connections at the power dist/fuse.
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
386
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
I'm finally getting back into building a system after many years. I figure I'll document what I do. Here's my truck I initially wanted just a...
Has anyone bought/used a pre-fab underseat F150 SuperCrew sub box in a SUPER-CAB? 2015-2020 in particular I know the super crew seats are...
camdogg4570
camdogg4570
Louisiana
akheathen
    May 18, 2024
    May 18, 2024
