f150 box help
  • 4
ampresearch
FL
hello all
I recently purchase the following items
two Kicker 06s15L7's subs
one Kicker 06 ZX1500.1 amp
these will be going into a ford f150.extended cab. the subs will be inside the truck not the bed.i have removed EVERYTHING from the back of the truck so I have lots of room.
I have decided to go with a ported box. the problem is i have always done sealed and dont know a whole lot about porting. I am looking for this to be a daily driver but i want the ability to really hit hard every now and then when the mood hits me. i was thinking of tuning some where around 35Hz. does this sound right?
I also need help with the box itself. the box size will be as follows
57" long
20" deep
22" tall
the subs will be point up at an angle facing slightly forward so the back of the box will be 22" tall but the front of the box will only be about 18".
what i need to know is port size. I find all sorts of info but nothing that that i fully understand. i dont know if i should use slot port or round ones. and i have no idea how long or big either needs to be. can someone tell me what size a slot port would have to be as well as round so that i can start to build this thing.
any help would be GREATLY appriciated
BTW i can put the por any place but on top.
the side would place the ports facing the walls of the cab about 10 inches away.
the floor would point them under the two front seats.
the middle would place the port right between the two seat firing at the dash.
opinions on what would be best would be great
Here is one I made for an extended cab f150.
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
They really are. Fit to perfection! Sounds Good Stereo are the best.
ampresearch
ampresearch
FL
hzsogood
    May 31, 2024
    May 24, 2024
