F150 Sony sub install
  • 3
So I have done a lot of research about this and I know that some people might say just search for it but every post I've looked at gives me a different answer. I have a 2013 f150 lariat with the Sony system and I want to add a different sub. Some body said I could just buy a line out converter (I was looking at the LC2I) and then just connect it to my speaker wires. Is it really that easy? Another forum I read said that there was a lot of other stuff you had to do, so I just want a definitive answer before I buy all of this stuff. Also what is the best sub and amp setup for this truck that is not crazy expensive?
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
6
They really are. Fit to perfection! Sounds Good Stereo are the best.
7
Tcrosby2011
Tcrosby2011
Thomasville GA
Tcrosby2011
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
