Factory Sound Dampening
  • 2
itln.stln
I've got a 99 mustang that I'm planning on installing Second Skin throughout, however as I removed the trunk panels and carpet I noticed that the factory had already installed some dampening. My question to you guys is; is it worth the trouble of removing the factory dampening before installing the Second Skin stuff or should it be okay to just lay the Second Skin over the top of it?
Thanks
Cool, thanks for the info. While I'm here I might as well ask another question. Is there any benefit to applying sound dampener to the inside of the doors or will it cause issues with the window mechanism?
I have a 2011 Yukon XL slt with the factory Bose system that has rear overhead dvd and rear radio mounted on the back of the center console as...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
itln.stln
itln.stln
Arizona
itln.stln
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
