Used car, factory plug clipped, how screwed am I?
  • 5
Elkins45
CarAudio.com Newbie
I bought a 2009 Scion xB this week. It has a P.L.Z MP-901 touchscreen media player and backup camera installed. Unfortunately I hate it because:
1. The steering wheel controls don't work.
2. The AM radio doesn't work at all.
3. The Bluetooth randomly mutes itself. It stays connected and the phone still thinks it's playing but there's no sound.
4. The appears to be no balance control anywhere in any of the menus.
5. There's not a physical volume knob.
On the bright side, at least the backup camera works, not that I really care because none of my other cars ever had one.
I dropped $30 on a used factory Scion radio in the hopes I could pop it right in, but whomever installed the aftermarket unit chopped off all the plugs rather than wiring in an adapter. I discovered this when I pulled it out today. Here's what I saw:
How much of a mess is this for someone to fix? At this point I figure I might as well buy a new, working aftermarket unit rather than the factory radio because most of the cost will be in paying someone to fix the wiring and a decent head unit will only add $250 at most. Maybe a bit more if I buy one the camera can plug into. Thoughts?
If it doesn't have the JBL amplified system in it then these will replace the OEM wiring harness the other person cut out allowing you to use that used radio.
OR if you want to still used a aftermarket radio then this will include that harness above but will also allow you to wire in an aftermarket radio while still using those OEM plugs so you don't have to do what he did.
https://www.amazon.com/dp/B08XK4RXFD/?tag=caraudiocom-20
question is does he have an aftermarket amplifier in there because there is a pair of 2 channel rca's in there for some reason.
Thanks for the quick and very helpful reply. I'm pretty sure the amplifier was removed by the previous owner. I remember seeing some unconnected blue wires in the compartment with the spare tire.
I have no expectation that you would know this, but is there a schematic for the factory wire colors online? I have little hope the wire colors on the replacement harness will match LOL.
That should help. Or do a search on yahoo for 2009 scion xb oem radio wiring harness and it should be the 3rd one down iirc
or this one
or maybe this one click scion xb wiring diagram pdg and go through it. looks like those xb's wiring are all the same for those years.
or this one
Thank you so much! Your Google fu is better than mine because all I kept finding were sites that wanted a credit card.
Eh I hate Google search and tbh Google website period. Only thing I like about them is Android and that is it. Hence why I use yahoo search for that stuff.
Anytime hopefully some of it helps.
One last question: do most aftermarket units use the same connector? It would sure be convenient to just pop in a new unit without having to deal with all that tape and wire nut disaster.
Most use the standard 16 pin connector. The issue is that is an Android radio. Those may use a non-standard connector or just ill fitting. The wire color code should be the same, so it should be as simple as removing and splicing one wire at a time.
Sorry, but I'm back again. It's even worse than I thought. The factory radio has five different input connectors. The two marked in green in the first photo are the ones that come in the replacement connector kit. I have the luxury of having access to an identical car so I pulled out the factory radio and looked at it. Four of them were used. One is probably for the steering wheel controls and the other is likely for the iPod and AUX inputs that were built into the center armrest of these cars. The fifth (unused) one is undoubtedly for satellite radio.
The idiot who installed it clipped all four of the existing plugs, so I need the other two (circled in red) to restore full functionality. I tried installer.com with no luck so I guess it's time to start searching again. Maybe I'll see if I can pick one up from Toyota.
This is what an unmolested factory wiring configuration looks like:
I think I'm near the point where I just pay someone else to fix it. What a mess!
I think I’ve figured out that the one closest to the corner is the steering wheel and the one above it is the remote aux/iPod interface.
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
5
950
I own one of the S.M.S.L SU-1 MQA MQA-CD DAC. I got it to play off my stable platter CD player, a Pioneer Elite PD-59 that I use as a transport to...
10
871
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
12K
Poly fill traps the rear wave of the speaker keeping it from reflecting back and hitting the cone. This reduces 2nd order and 3rd order distortion...
9
Elkins45
CarAudio.com Newbie
Elkins45
Kentucky
Jimi77
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
Latest topics
