Factory stereo integration question
  • 1
Masted85
CarAudio.com Recruit
62
4
Alabama
I'm looking to add amp outputs to my factory Bose stereo in my 11 Tahoe Z71. What is the better option Line Output Converter, suggestion would be helpful, or the Plug and Play option (PAC as one example)? Any other info needed just leave me a reply and I'll get back ASAP.
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
6
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
Masted85
Masted85
Alabama
Masted85
Decebal
    Jun 10, 2024
