Swapping factory Honda Element stereo 2005 with DMH1770 nex
  • 3
RHill234
CarAudio.com Newbie
11
KCMO
I am switching a factory Honda Element 2005 am fm single CD player digital display NO subwoofer to a Pioneer DMH 1770 NEX. I was wondering what harness i can use from the factory wiring to the new radio to keep from having to splice wires if possible? I can call Crutchfield if I need to.Thank you R Hill
If you had bought it from crutchfield or sonicelectronix those install kits are free. You will probably need a mounting kit as well.
Metra Dash kit below at the very least you can take the metra numbers to amazon or ebay. Just don't buy something from walmart
Scosche wiring harness which will go to the Pioneer wiring harness and just plug into the OEM harness so no splicing required.
Metra Wiring harness same thing as the Scosche just a Metra number to help you find one. Doesn't matter which one you get both the same and will do the same job with no splicing into the OEM harness.
Now if you have a OEM Amplifier in that vehicle which some did then you will need this wiring harness instead of the one above. So make sure you figure that out
Usually on a Honda you need an antenna adapter as well
If you have steering wheel radio controls then contact the makers of this item and find out if it will work otherwise your steering controls won't work at all.
I did not say I have no in box wirin
I should have said I have no wiring at all I bought radio only. What do I need for pug and play DMH 1770 nex to Honda Element 2005 7 speakers am fm
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls and if so do you want to keep them.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
You can always reset it by disconnecting the power from the unit. If it is one of the loads of cheap android head units available online on...
RHill234
CarAudio.com Newbie
RHill234
KCMO
Firewalker
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
