Few questions about 2500wrms system.
  • 2
Jager
I will be running a FI BTL 15 d2 off of an Orion 2500d. Box is about 4 cubes tuned to 34z. I have a 180 amp alt, an optima yellow top for front battery, and a batcap 800 for back battery. I will have big 3 done in 2/0 welding cable.
questions:
1. Is it worth having multiple runs of 0 gauge from front battery to back, or will 1 be enough?
2. Is it worth getting a second batcap for my trunk, or should I install what I got, see what my electrical is at, and just go from there?
3. Do I need an isolator inbetween batcap and optima?
4. Do I need to fuse between Batcap and amp?
questions:
One would be ok, but multiple runs wouldn't hurt...
Yes. That one 800 is not going to cut it. Wait...what are you wiring the amp to? If you're wiring it to 1 ohm then no way in hell. Also, if that Yellow Top is under your hood as a starter battery you might as well replace it too. Deep cycle batteries will ALL die eventually if used as a primary start up because they are not designed to discharge/recharge like a regular AGM lead-acid.
Not unless you plan on running your system with the car off a lot.
I would, but it's not a "must."
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
395
Jager
Jager
Alexandria, MN
528hz
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
