few questions for 4k rms
cocoleveo7686
MA
Currently running ab vfl 175.1 and alpine pdx 5.
I pulled out all wiring and gonna rewire with sky-high. My question is should i go with 2/0 gauge for 4k rms or is 1/0 gauge enough? Its only $20 difference to go with 2/0 but if its not needed it will be easier to run 1/0 thoughts?
Also i have a singer 270a hairpin large case alt, 1 kinetik 2400 in the rear and going to put a xs3400d up front is that enough battery and alt to run .5 ohms on my vfl?
Thanks in advance
$20 to ho from 1/0 to 2/0? Where at?
And thats enough electrical for probably 2.5k but i wouldnt do 4k specially on .5 with that id say get 2 d3100s
---------- Post added at 12:01 PM ---------- Previous post was at 12:00 PM ----------
But 1/0 is enough if you have dual runs
$20 to ho from 1/0 to 2/0? Where at? And thats enough electrical for probably 2.5k but i wouldnt do 4k specially on .5 with that id say get 2 d3100s
on ebay its 1.00 difference per foot for 2/0 vs 1/0 so for 20 dollars more i can get 2/0
is 2 runs of 1/0 bigger or the same size as 2/0? Just thinking if i ever upgrade to another vfl.
2.5k watts??? i highly doubt that. 200 ah worth of batteries plus a 270a singer alt would beable to be around 4k i would think. I have always run my amps at 1 ohm but i heard the vfl really shines at .5 ohms and i wanna make sure if i run it at .5 ohms i can keep voltage at 14 on full tilt.
I have the set point at 15.2 so it should go down to about 14.5 after being warm.
15.2v will swell a AGM.
Its 15.0 sorry. Thats cold start after few mins it should go down to 14.5
Think im gonna do 2 runs of 0 gauge. Does that mean i need 5 fuses total? 2 up front at the battery, 2 at the rear then 1 off the wire going to the amp?
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
536
cocoleveo7686
cocoleveo7686
MA
MrFoca
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
