Few things I won't be using for stuff I could use
  • 6
garychoffmann
Missouri
Soundstream tra560.2 beast of an amp to run a set of comps or multiples. Some ridiculous .0012 rated distortion. Been told they were under rated but I don't believe this one has ever been powered up. Bought years ago. 140x2@4 I believe is its rated.
Helix hxa600 mkiii 5 channel. Beautiful sounding amp. Great small sq system amp. Download the manual.... A lot of controls. Plexi has seen better days but fully useable.
New Bravox 5.25 components. My last set of these from bravox buy out. Great little music players
Clarion eqs746. NIB
Polk mm840dvc's. Hour most of playtime
Sony cdx gt 620 in
Pioneer eq6500 old school bliss
Old school audio control overdrive
Memphis m3 12. Looks to be painted all black.
2 ARC flatline 12's. Not played since recone. Comes with useable factory drop ins from the recones. They were reconed for use in IB with a lighter cone assembly and slightly stiffer spider. I do remember these modeled pretty well in 1.1 sealed and 1.5 @ 30 hz. I can tell you more if interested. In IB they will either have to have a potentiometer or a bit of eq
I am looking for sundown e 12's or 10's. 4 channel amp. Small 1 ohm mono amp 600 ish watts or anything that catches me eye. Thanks
Polks are traded. Arcs are on hold. Have a phoenix gold tantrum 1200.1 4 ohm monster. Also a diamond d6 300.4 I can put on the chopping block
Lookin for a decent sub amp or that 140x2 I have a wtt thread also with comps, batt, amps ect check it out and see if anything you want , I have a set of hertz dieci coax and hertz dieci comps both bought at same time not a min more than 2hrs play time at the very most. Was in wife's murano for a very short time like new
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
607
garychoffmann
garychoffmann
Missouri
mylows10
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
