FI Bl-18v3d2/AAK-4000.1d... lovin' the output
Post a video...
Once I meter the thing I'll post a pic of my number and probably do a new vid... this vid was when the amp just got installed, single starting Agm with the 250A alt only and the sub was in in 9.04ft3 net. I could not really open it up... now it's a completely different animal with the enclosure volume change and stronger electrical. Jeezus... the thing does fine by me now... at least for a bit... 🤣
Hey @shredder2
What batteries are you running with that AAK 4000.1D? I'm looking to run the exact same amp on a Fi SP4v2+ 15"
I'm probably at the basic minimum (or just enough) as long demos are not what I'm into, but where it's at currently seems sufficient for my purposes... at least this week...  :eyebrow:
At this point I'm about halfway done replacing wire, cleaning up the runs and tuning/testing it out... but I'd compete as is just to see where it's at
Current electrical...
250A Ces
Duracell H6 Agm... https://www.autozone.com/batteries-starting-and-charging/battery/duralast-platinum-battery/319460_607227_25697
Little Northstar Sms Agm 80... https://gpcaraudio.com/bundle-northstar-smsagm80-gp24-terminals/
I wish you could see/feel where it's at volume wise and voltage wise currently... kinda hard to explain the results over the interwebs but I'm very pleased.
Could it be better electrical-wise?.. I'm sure a 300A and some serious reserve would be in order at .5 but I'm at 1 ohm nominal and it's doing fine Imho.
I kinda lean towards a old school rap/rock tune and that coincides with the vehicles cabin frequency... Spl is just a nice bonus as I love output. It burps pretty well... it's got me grinning like an idiot every time I open it up.
250A Ces
Thanks for the info man! I'm sure it sounds incredible, sure does look it. Just looking at my Fi sub gives me chills. Gotta love american subs!
I'm still on the edge of whether to go full lithium or agm. Already have a XS D3400 and D5100R Mechman 240, SA12's on a DC 2k but decided to bump up the power and switch to a single 15 tuned at 30. Just setting up the layout of my trunk now so I have alot of work ahead of me. I post all my stuff on another forum check me out if you want to at: https://www.stevemeadedesigns.com/board/topic/211131-honda-civic-coupe-08-2k-daily-headaches/   or on instagram: joshdashef1
  • Locked
Up for grabs is a Gravity Warzone 4000.1 mono amp. This is a solid low budget sub amp that does a solid 1000 or so watts at 1 ohm, maybe a bit...
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
shredder2
CarAudio.com VIP
shredder2
Az
Joshdashef1
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
