Fi BTL 15" vs DC Level 4 15"
  • 7
JoeK
Ringtown, PA
Both of these subs can be had by me for $375, but the question is, which one?
I'm running a Skar 1500.1, and later on im going to buy another one and strap them.
The sub will be going in my current box, 3.2cu.ft @ 32hz to replace my PB 3xl
Level 4 would be better in that enclosure but, the better sub is the btl. You need 4 cubes for that btl.
That box is almost the biggest i can fit into the trunk. The hatch is too small for 4 cubes, or i would have the PB in that now.
Even 3.5 cubes would be an improvement. The biggest you can fit is what you need.
The problem is that if i overmeasure im out a box and if i undermeasure, then i can always measure more; this box just about barely fits in the trunk now
Just to get this right; if i were to use the same box, the DC level 4 is better?
The prices i got for the DC were direct from DC by the way.
Is this the UFO motor or the N2? If it's the N2 they require smaller boxes so 3.2-3.5 would be adequate. Also on that power/enclosure a Level 4 would probably get way louder. 1500rms would only tickle a UFO.
Yes that box is better and the power is better for the sub. You can usually get the price knocked down a bit from the dealers.
At that price it is definitely the UFO in which case 3.2 is not enough. Also on that power either way even if it was a N2 he would still need a bigger box to get the sub moving.
I do not know which motor. But the person who recommended me to Fi for my upgrade told me his sub is around 2500w rms and costed $375; hes running it off of an MB quartz 1500.1 and its freaking loud!
Unless we're talking about pairing them with amps of those ratings I wouldn't call that honest, but probably consistent with what the vast...
11
  • Locked
Negative 1aespinoza . The spider landing is to big on the newer 12 spokes like you posted . I need the old school 12 spoke. Nobody here has...
3K
Factory. 2021 Chevy Silverado custom trailboss
9
876
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
899
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
757
JoeK
JoeK
Ringtown, PA
JoeK
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
