FI Q in a bigger box????
for a sealed 12" you should be at about 1.2 cu. ft. Ported around 2.35 cu ft.
Q 12 – We recommend using a sealed box in the neighborhood of .8-1.5 cubic feet of volume.
Ported box we recommend using 1.8-2.5 cubic feet @ 28-33Hz (I personally think that a 32 Hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per one cubic foot of enclosure volume.
Does it have the original parts? What kind of power do you have?
The box is sealed. I am powering the sub with a JBL bp1200.1
I have been reading that I should do a ported enclosure. So, after measuring the sealed box I have, I was just wondering if I should just cut a hole and port it.
Inside is 19.75" x 13.25" x 10.25"
The corners inside are reinforced by triangle chaped wooden sticks. Those are 10.25 long and support the depth. Trying to make sense.
Here is what I am having done..
2.43cuft@33hz
25w
20d
15h
6"aeroport
And "Boomsday" is doing it for me. Awesome communication. I will let you all know how things turn out.
2.43cuft@33hz
25w
20d
15h
6"aeroport
yea that should be awesome. It's gonna get he11a loud compared to your sealed box. Hope you like it.
I have mused doing that, but I like keeping my jalopies looking OEM. Now if I knew how to fiberglass like NSTALN, I would have done it long ago.
22
Back in the day there was some that went directly into the dash and then came out when powered on. Some of those were bigger then the size you are...
6
Damn.. thank you man... I wasn't expecting you to do all the work for me but I'll definitely take it lol. Thank you so much and also thank you...
5
I sincerely appreciate the advice. I've made some changes to the design of my box and it's coming out to +8.99% larger than spec. I'll still be...
7
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
jeeper2269
jeeper2269
Somewhere, OR
jeeper2269
