First 6th order build, trying to grasp the concept
  • 2
Tell me if I have a clue what I'm talking about, or if I'm way off:
6th order series tuned is basically a ported box inside another ported box, right? I mean, that's what it looks like to me anyway. From what I've read on various forums in the last couple of days, I gather that the "inner" box (rear chamber,) should be built slightly smaller than spec for required volume (I don't really understand why, but I saw this on two different sites) so if my sub calls for 4.25 ft^3, build it for say 4, or maybe even 3.75 ft^3 and tune for my sub's Fs (29.6.) Then for the "outer box" (front chamber) build it to 1.5-3 times the volume of the rear chamber and tune to the 40-50hz range. Yes? No? Am I close?
I've only built a few series tuned 6th's, or clamshells. Rear tuning needs to be as low/lower than you plan to play as sub will unload easily below tuning. Front tuning should be at least 1 octave higher than rear tuning. Mine was to spec for ported size/port area for the subs I used.
You need a TL and build it so you can mess with front/rear tuning/port sizes to dial it in. Def not as easy as ported or a 4th order but they can be HELLA loud if done right....
I will make some small changes for the final enclosure. When I modeled it for the normal ported enclosures I saw some issues with port speeds...
21
3K
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
553
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
4K
DanieltLawson
DanieltLawson
Colorado Springs, Colorado
mlstrass
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
