First audio system, need help
  • 6
I think you can add pulsing lights to anything, although they might mess with your resistance, so be careful if they do.
Just get a head unit with pre-outs and an amp and sub in a box, or a powered sub-in-a-box if you want it to be easy or if you have space constraints. Buy the best you can, because the dumb stuff ends up being a waste of money. Make sure you run a large enough gauge power wire, fused close to the battery. Properly ground your amp too. Class D amps don't need much juice these days, so it's much easier than it used to be. They tend to run really cool too, in my experience.
I like Rockford Fosgate PUNCH amps, and JL Audio subwoofers. Alpine head units and JBL speakers, but I'm old.
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
938
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
Rogue Bear
Rogue Bear
Indiana
motochrome
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
