First post need help please. Electrical help
Hey guys, First post on the forums and i need help lol. My current setup is 2 15" soundqubed hds300's wired to 1 ohm each on a hifonics brx2400.1d and the way i was planning on running it was i was going to use my xs power d3400 in the rear but i wasnt going to have a charge cable coming from the alt, i was just gonna charge the bat when it needed it. my question is would this be a sufficient way to run the setup? or would a 0 gauge run from alt pos to rear bat pos be better that way the alt manages the charging? or is it bat pos to bat pos instead? Btw i'm in a 2009 escalade that has a 160amp alt in it. a tech support guy from xs power said the run of 0 gauge from bat pos to rear bat pos would work but would the alt be able to supply enough power? or is a new alt the answer? like a 250-300 amp ho alt? I need all the help I can get and any response is a good response. also If i left out any information, please let me know and I'll add it
With that amp you need the bigger alt. singer makes a 350 that would leave room for a bigger amp. I just ordered 2 or them for a buddy also the pos cable from the alt or battery pos is fine either way
Ok so the tech support dude also gave me a link to a kit with everything I need to do the wiring from starter to secondary with fuses and grounds and stuff like that. Is doing this without the new alt going to be enough to run my system? and i'm already doing the big 3 although i dont believe it plays a part to doing this just doesnt hurt to have
---------- Post added at 07:41 PM ---------- Previous post was at 07:40 PM ----------
xs power ak-3000
Issue is with most of the gm trucks. Mine included they can't run more than 1000 rms without straining the electrical system if stock. So you need to beef it up quite a bit. The hifonics amps are very power hungry and need to be fed properly usually the big 3 will help with battery strain. But it can only do so much same with a better battery. You have to be able to make the power to use it if you get my meaning If your not going any bigger amp power wise. Then a 225 or 250 amp alt will suffice. But if you think you might want more down the road. Then get the 350 amp
I wont be going bigger amp wise but I might go with the 350 anyways juuust incase I decide to up my mids and highs. and you said you have had experience with two of the 350's? How do you like them in terms of performance? Also Do you have a link the the dealer you bought them from?
just realized singer is a guy who makes alts i found the site
You can't go wrong listening/dealing with my lows, I just got one of those alts, he was extremely helpful through out stayed in contact letting me know every step of the alt build and made sure I got all the schit I needed for the install, hey jim.
ok looks like im deffinatly going with singer for sure
Yes. Ring terminals will work great. crimp them pretty good. You can hit with solder to make a secure solid connection, and then Heat shrink over...
495
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
Yes, Winky was triggered and butt hurt enough to start **** when I wasn't even talking to him.
Looking for an inexpensive double din head unit that has the following: Front/Rear/Sub outputs XM Ready Just want some ideas
Have you spoken with one of the reps? They should have all that info on file.
Stevenajpvv
Boca Raton, FL
mylows10
