First speaker and amp install.
  • 3
s0nl33t
7
Canada
Hi,
I'm doing my first audio install. I have two pair of JBL Gx-602 6.5" speakers. I'm looking to replace my front left and front right speaker with one pair of the JBLs for now.
I have picked an amp out. I think I have the right calculations for it, but i just want to make sure this amp will be enough to power all four speakers if i decide to install the other two later on. I'm not looking to add a sub.
Amplifier-
https://www.amazon.ca/JBL-GX-A604-435W-4-Channel-Amplifier/dp/B00I5WEB8C
Speakers -
https://www.amazon.com/GX602-180W-2-Way-Coaxial-Loudspeakers/dp/B00MUKMYNY
Thanks.
Looks good to me. If you want better sound qaulity than you would be better served by a component set and slightly more powerful amplifier. Don’t forget the oxygen free copper power wire, fuse, and speaker wire for that amplifier and something to seal the speaker to the door. If you can put a little sound deadening mat such as Dynomat around the speaker and on the outer shell of the door than that will help with the bass output.
Thanks for the mat idea. I grabbed some today, and I picked up some extra speaker wire incase I decide to wire the rear speakers. I've also got a amp wiring kit on the way as well, so that has all the appropriate wiring and fuse harness. As for the equipment, don't need anything more than this right now as I'm just diving a beater haha.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
369
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
337
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
s0nl33t
s0nl33t
Canada
s0nl33t
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
