first wall, need advice
  • 2
mrray13
uz some fegbags
4,805
IL
ok, here goes.............................
in about two weeks, my bro-in-law and i are going to wall his firebird for 2 id splmax(not real for sure what they're called)15's. i guess we need about 3-3.5 cuft for each and want to use a single rectangular port. the subs are dvc2ohm and to start are going to be pushed by a rf 800.2. here's the questions..........................
1) where do i start?
2)better to build inside the vehicle?
3)shape a big concern?any shapes take away from spl?
4)anyone know how i can get ahold of matt borgardt?
5)any other suggestions will be appreciated!!
thnx in advance!
Here's Matt's Email address idtech@imagedynamicsusa.com
Start by gathering all the info about your particular subs you can. Then start crunching the numbers with a box building program or two. Find the optimum enclosure and tuning for the space you have to work with and your vehicle. To me it's easier to build as much as I can outside of the car. But when your building a wall it's hard to do that. I havn't found the shape of the enclsorue to be a big concern. Unless your building this wall in a school bus or something //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I use bassbox pro 6.0. I got it at http://www.partsexpress.com There are several other good ones out there also. I believe I remember Bigbassman, and jlaine using another that they liked. I can't remember right off the top of my head. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thnx ramos, i've downloaded that WinISD, as well. the only problem with it is, i'm not for sure about the model number of his subs. it has alot listed for id, but which ones?! anywho, i'm gonna get this thing your talking about, and see from there.
thnx again!
hey, where/ how did you get bassbox pro 6.0 for that link? i can't find it!
thnx again!
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
882
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
mrray13
uz some fegbags
mrray13
IL
ramos
    May 16, 2024
    May 16, 2024
