flat dual inputs
zx_htL-k9Bkf5aqWAQtdUoPa-yC5tcahhNCGip7-jtgjYD-LmzKMckDOQur1NFxfryG3vKuBd1p7fY5hYLEgJJBfPIjvV67g7NVW-AqzhEnh5EBY7t416HMkQGxZxGhbSoQ8IP2tJ1tyC52b3g7PkmkK_XHV4wi4VvtfbZKdBXgi2bnjJ6-SOPhxTlBOWy7Jg3Y0UuQPNXdHDQYx-IcqQds5nEVkYE6L8LeQc7kTKi-j4ifKlDS92vinDFUC0yKY0h1jl4hAQCzq9HmoMJHtoPQpDtbY47SE_ViY_ncm7H0bdt5zbCgMGoSZE0KDWx93h6BHwcS2iXUk9fvRRXAzR6UDagaaKxT5u0rOuncHEwsw-b15Cqd7qpODFwEvVyhSmTY8Rbc6_GMiWPAMWcrGoj5ls20a4bOA7GZWc2CdL2cgmbsrhtsrx_TH_hEnM_B8r1q02AQxAo7vq1FMw2kACn9LyWrxXEFH9fOb0LwRSf0SKK3Uf5gb-DYgMH2q3I29MeOoMcCvxxvnB2Xven2iyg=w720-h406-no
What do y'all think. I have no mill to machine a "proper" dual input. Simply I can tap those holes and use terminals.
If i were going to make something like this, I'd round the bottom of the input into the amp and maybe some sort spot on top for the set screw of the amp to clamp down on better. Other than that, should work.
162
862
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
845
jnk2013
jnk2013
san antonio tx
jnk2013
audiobaun
    May 19, 2024
    May 19, 2024
