For Sale Brand New QSC K12.2 K.2 Series 12" 2-Way 2000 Watt Powered Speaker
  • 1
bigstocks
CarAudio.com Newbie
5
Configuration    Multi-purpose, 2-way powered loudspeaker
Transducers    LF Transducer: 10" / 254 mm, cone
HF Transducer: 1.4" / 35.6 mm titanium diaphragm compression driver
Frequency Response    Frequency Response (-6 dB): 56 Hz - 20 kHz
Frequency Range    Frequency Range (-10 dB): 50 Hz - 20 kHz
Nominal Coverage Angle    90° Axisymetric
Maximum SPL    130 dB @ 1 M, peak 124 dB @ 1 M, continuous
Amplifier    Class-D
Peak: 1800 W (LF), 225 W (HF)
Cooling    Low-noise, variable speed fan
Controls    Power switch
Level Dial: 3
Rotary encoder (push)
Selection Buttons: 2
Indicators    Monochrome LCD Display 1.8 x 1.0" / 45.0 x 25.4 mm
Power LED (Front and Rear): 2
Input Signal LED: 3
Input A Mic selected LED
Input B Hi-Z selected LED
Limiter active LED
Connectors    Mic/Line Input and Hi-Z/Line Input: 2 x locking XLR/F 1/4" / 6.35 mm combo
Stereo Input: 1 x 1/8" / 3.5 mm TRS
Loop-Thru Output: 2 x XLR/M
Mix Output: 1 x XLR/M
Power Connector: 1 x locking IEC connector
Power    AC Power Input: Universal power supply 100 - 240 VAC, 50 - 60 Hz
AC Power Consumption (1/8th Power): 100 VAC, 2.1 A / 120 VAC, 1.9 A / 240 VAC, 1.1 A
Enclosure Characteristics    Enclosure: Impact resistant ABS
Attachment Points: 2 x M10 threaded inserts plus pull-back
Color: Black (RAL 9011)
Grille: 18 Gauge powered coated steel, internal cloth lining
Regulation Compliance    CE, WEEE, UL, China RoHS, RoHS II, FCC Class B
Dimensions (H x W x D)    20.4 x 12.6 x 11.8" / 518.2 x 320.0 x 299.7 mm
Weight    32.0 lb / 14.5 kg
Packaging Info
Package Weight    38.8 lb
Box Dimensions (LxWxH)    22.0 x 17.5 x 16.5"
For order placement and more information kindly contact us through the following below.
E-mail : otownborn@gmail.com
E-mail : gskconsults@gmail.com
i know that don’t change nothing thought i would share just let me know k if u want to text or email about it i will send u my info
6
e heard decent things, I've not used it, but for noobs, good place to start with that new DSP setup...
COMPLETED Full system sale
Changed my mind, the jetta is staying as-is and I'm buying the new car anyway, close this *****! Matt
bigstocks
CarAudio.com Newbie
bigstocks
bigstocks
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
