Ford F150 or Explorer Door Panels
  • 1
dgaf
Swollen Member
755
727, FL
CORRECTION Expedition - NOT Explorer
Each holds four 6.5" speakers
I bought these over a year ago, to go on my 1997 F150, never got around to it. They were on a 1998 F150.
I'm told they fit 1997 - 99 F150 and 1997 - 2002 Expedition
All the clips look to be in good condition, the back just looks like factory, should be a simple install\swap out.
There is some damage to the end of passenger side panel. Other than that little area, they look in pretty good condition.
$150 shipped, or $100 picked up in the Tampa area. Open to trades.
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
They really are. Fit to perfection! Sounds Good Stereo are the best.
7
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
902
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
dgaf
Swollen Member
dgaf
727, FL
dgaf
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
