Ford factory amp and sub
  • 4
Toomanytoys
CarAudio.com Newbie
14
4
Does anyone here have any experience with the Sony THX sound system in the 07-14 Ford Expeditions and Lincoln Navigators?
The reason I’m asking is I want to replace the factory 8” sub in the drivers side rear panel with something that can hit harder but I want to keep the factory enclosure. So what I need to know is if anyone happens to know what the dimensions of the factory sub are and the wattage specs on the sub and amp
It’s a real pain to get to the factory enclosure so I only want to do it once
You will not find a subwoofer for that enclosure size and stock amp that will be louder than the factory subwoofer. Throw some poly fill in the enclosure and call it a day.
I wasn’t planning on staying with the factory amp. I was thinking along the lines of the nvx or sundown compact amps
Have you tried looking for a factory replacement online? That should have the dimensions and possibly the wattage. Also, try crutchfield.com and type in your vehicle. They will give you options of speakers and subwoofers that will fit your vehicle. Good luck.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
444
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Toomanytoys
CarAudio.com Newbie
Toomanytoys
huberoy123
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
