Ford Focus help (urgent)
  • 2
Tek18
KY
Hello,
i'm installing a new headunit into a 2009 Ford Focus and i completely forgot to purchase a wiring harness, so we go to the audio store to pick one up fast and the guy there says we need a $130 adapter otherwise we will have check engine lights messed up etc.
I have noticed that the passanger seat belt light is on when i have it on, and also there is no temperature where there use to be showing how hot/cold it was.
so the question is.
A. Do i need this adapter?
B. where can i get the harness?
thanks
ps.
this is what he said we needed
HARNESS METRA XSVI-5520-NAV Install your new car stereo using the existing factory wiring and connectors In some Ford / Lincoln / Mercury vehicles there are no 12 volt accessory wires in the factory harness. The XSVI-5520-NAV is designed to provide a
if we dont get that and just go straight harness, what are we missing?
talked to a guy on crutchfield and we need a " PAC system? " PAC Ford Radio Replacement Interface Allows aftermarket radio installation in select 2005-up Ford-built vehicles (model C2R-FRD1) at Crutchfield.com
where can we get one cheaper?
---------- Post added at 05:38 PM ---------- Previous post was at 05:38 PM ----------
yep, kinda screwed on that one. Have to do the same for newer GM/Chevys. lots of newer cars are this way
Wiring color code should be ISO, just like American radios. If you get your vehicle specific radio harness, it should have the same colors as that...
In that case, a mono amp will do just fine. You can always use the bass knob to blend the sub with the front stage. Using a mono also opens a...
609
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
Tek18
Tek18
KY
KRYPTO
    May 18, 2024
    May 16, 2024
