Fosgate Amp Fully Exteding Sub and Holding it There...No Sound
  • 1
Thejkaz
I have a Rockford Fosgate 301S that I have had for many years. It has been in several vehicles and gone through even more subs. I took it out of my SUV when I sold it about 2 years ago and has been sitting in the trunk of my car disconnected since. I recently decided to set it up, ran all the wiring, installed line out converter from the bose sound system and fired it up and bam nothing. The sub fully extends but no movement and no sound. I disconnected the inputs but the sub remains fully extended. I quickly disconnected the sub and began some testing. I moved the ground twice with the same result. I connected my multi-meter and I am getting almost 30 volts DC from my amp WTF. It was working perfectly when I removed it from my SUV. IT has not been knocked around or gotten wet. I opened it up and there are no burns, no bulging caps or anything else that I can visually see wrong with the internals. I know amps go bad and Mosfet chips fail but I see no reason that my amp is doing this. Any advice would be greatly appreciated. Thank you, Justin
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
Thejkaz
Thejkaz
Dallas, TX
Thejkaz
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
