Fosgate P600x4
  • 2
bamby
So a friend of mine has a P600x4 that stop working. The amplifier damage the IRF1404Z mosfets. Here are the photos
I dont know why this happen so i start to look around. When i remove the cover from the other mosfets notice that one IRF3415 and a IRF5210 had rust plus some resistors were covered in something that looks like battery acid( I dont know if the correct term is sulfate). He has a carwash and moves water and some wet things in his trunk maybe it got soke in water?. Here are some photos
Full look of the amplifier
The problem is he bought the amplifier from a non authorized dealer so it has no warranty. He called fosgate and they told him they would charge him $190 to fix the amp so its a no go. I was going to replace the mosfets and check the resistors but i dont have an schematic to know the exact values.
I graduated from electrical engineering recently so i have a little knowledge if some one has some tips or recommendations and can tell me other thins to check it will be appreciated thanks.
Sorry for my bad English.
you're going to get more help over on DIYMA or MAF in the amplifier guts or internal repair section, there's a few here who know amplifiers well but its unlikely youll get the information you need here due to them sporadically checking the site
thanks
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
bamby
bamby
United States
bamby
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
