Fosgate T2's
  • 4
Fosgate24565
11
Ohio
I'm kind of new to all of this stuff and I have one question. I have two rockford fosgate T2 12 inch subs that are dual 2 ohm. Could I wire them down to .5 ohm on a soundstream TA1.3000D amp? I might sound stupid sorry. I'm new to all of this stuff.
Not sure if those amps are .5 stable.What does your electrical look like?Any amp at .5 will need some good juice to feed it.
I haven't got the wires for it yet. So your not sure it will be able to do it?
I'm not familiar with that line myself.Maybe someone else will chime in.Just wondered about your wiring,alt voltage,batteries.Running .5 is hard on all that.If its not up to task then you'll either blow your amp,subs or burn the whole car down.Just a possibility.
Alright. I mean I wouldn't crank it all the time. I still haven't bought the amp yet just looking.
Not sure on that exact model.Maybe buy one that displays the power at .5 or get one that does proven power at .5 Thats what i would do.Research the heck out of everything.Comin here was a good start.Someone may jump in that knows more on that model you're lookin at also.
It'll do it on burps but I wouldn't do it daily and as stated earlier you had better make sure you have the electrical or you will be looking at a meltdown.....
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
Fosgate24565
Fosgate24565
Ohio
Fosgate24565
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
