I have a 2000 Jeep Cherokee Sport with Infinity Kappa speakers, Kenwood hu, MTX 10" subs and MTX mono amp. My issue is that when I installed the head unit in the first place, I could not wire the driver side door speaker using the harness, I had to run my own wire. When I tried to use the wiring harness, It would simply not work. So, I ran my own wire for that speaker only, and thought I would be just fine.
A little while after doing this, the driver side speaker started grounding out on the door that it is screwed into. I have checked, checked and re-checked the wire, and there are no cuts, tears, anything! The connections are good and I have had the speaker replaced, so I know the speaker is not the issue. It is not the head unit because I went out and got a new one today and it is doing the same thing.I
I have no idea what would be causing this to happen. I would appreciate any suggestions.
Thanks
Thanks
