please please help im stumped
TRAP$TAR
breakin glass
30
stc
ok so i have a 1200 mono hifonics amp 4gauge wire kicker rca cables pioneer hu and 4 kicker comp cvr 10's
gain set to about a little past mid way and bass eq is set all the way down and my subs will hit but as soon as they hit a certian point the will start to distort just sound so ugly i tried a different hu re grounded everything checked all fuses nothing but yet the amp worked fine in another car on another sub with gains set very low i dont understand i cant get them to hit like the use too please help
I think you need to check gains my man. I think you have it a bit too high to be honest.
EDIT: in short, if you turn your head unit to as loud as you turn it daily and set your gains you shouldnt set it to where your subs distort.
It could also be the subsonic or lowpass filter if you dont know what those do.
which way they are facing, what was your old car, whats the new one?
there facing toward the cab in a 1986 oldsmobile cutlass supreme same as caprice and i just hooked the sub wires to a differnt amp in a differnt car
they might be wired out of phase, also try turning them around and see what its like, you might have to do some rear deck mods or take the back speakers out to let the bass wave in
no my gains set to about mid way the problem occurs when the gain is past mid way or when i turn the hu up even with all loud settings off .... when i re wired everything it the subs worked fine beating it down for about 5 minutes then started distoring again so i had to turn the gain back up
thats a good idea cause i swear when i was pulling the box towards me and away from the cab they would start to hit then distort again when i moved them back
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
TRAP$TAR
breakin glass
TRAP$TAR
stc
TRAP$TAR
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
