SOLD FS: Alpine CDA 9856, OZ ME 15d4, JBL GTO 12
bjayjr5679
Father of Three
JBL GTO 1214
BNIB 10/10 condition
$95 Shipped OBO
SPECS:
• 12" Single 4 ohms Grand Touring Die-Cast Series Subwoofer
• Power Handling:
o Peak: 1400 watts
o RMS: 350 watts
• Impedance: Single 4 ohms
• Polypropylene cone woofer
• Rubber surround
• Tinsel wire protector
• Die-cast aluminum basket
• 2" Single 4 ohms voice coil
• Frequency response: 23-400 Hz
• Sensitivity: 90 dB
Minimum Sealed Box Volume 1.0 cubic feet
Maximum Sealed Box Volume 1.0 cubic feet
Minimum Ported Box Volume 1.75 cubic feet
Maximum Ported Box Volume 1.75 cubic feet
Specs form JBL
http://www.jbl.com/resources/Brands/.../GTO1214TD.pdf
2) OZ ME 15.4d
$135 Plus Shipping (kind of firm on this one because of me double boxing and peanuting this thing up to make for secure shipping)
Mint not in original box
9.5/10 (just cause its used)
Description: The Oz Matrix Elite series of subwoofers represent Oz Audio's obsession to create the ultimate in subwoofer technology. Every aspect of these subwoofers was designed and scrutinized to ensure maximum SPL and the ultimate in sound quality.
  • Diameter: 15"
  • Impedance: Dual 4 Ohm
  • Power Handling (RMS/Peak): 700W / 1400W
  • Sensitivity (1W/1M): 86dB
  • Frequency Response: 18-500Hz
  • Xmax (mm): 25mm
  • Fs (Hz): 27Hz
  • Mounting Depth: 8 1/16"
  • Mounting Diameter: 14 1/8"
  • Voice Coil Diameter: 2 1/2"
  • U-Turn Hyper Surround composed of dense UV treated foam, shaped into a nonstandard profile representing a "U". This design accomplishes two goals: The cone's surface area is maximized, therefore maximizing SPL output. Additionally, the surround's taller profile allows for increased Xmax and linearity.
  • Three layer cone comprised of two layers of braided glass fiber with a layer of nomex sandwiched in between to create a material which is extremely rigid, yet remarkably lightweight.
  • Competition style aluminum die-cast basket
  • Underlap cone attachment
  • The spider assembly comprised of blended cotton and nomex, called conex, results in a materail that is flexible like cotton, yet has the tensile strength of nomex. Additionally, the lead wires are interwoven into the spider to eliminate breakage during extreme SPL excursion.
  • Dual wound, 2.5-inch voice coils on a glass fiber former.
  • Cross-Vent intercooling through the basket to allow the voice coils to remain cool during operation. 8. 150 ounce triple magent motor assembly
  • Custom engraved chrome backplate with Oz Audio logo engraved. Additionally, the backplate has a vented radius.
  • Extended Coil Windings for Increased Xmax
  • Double Sided Engraved Rubber Gasket
  • Protective Rubber Magnet Sleeve
  • Specially Designed Vacuum Formed Dust Cap
  • Nickel Plated Push Terminals
3) Alpine CDA-9856
-$75 Shipped obo
-6.5/10 Condition. One light scratch only visiable in direct sunlight and a scratch on the side of the face.
-Also some scratches on teh volume knob
-comes with everyting from remote, box, cage, harness and I will throw in Ipod cable also.
SPECS:
Details:
  • CD player with built-in amplifier (18 watts RMS/50 peak x 4 channels)
  • flip-down, detachable face
  • plays audio CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA music files)
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE processing
  • three sets of preamp outputs
  • Source Tone Memory
  • HD Radio ready (requires Alpine HD Radio Tuner)
  • controls for an optional XM or SIRIUS satellite radio tuner
  • controls for iPod with Alpine's optional Full Speed interface cable
  • CD changer controls
  • clock
  • CEA-2006 compliant amplifier
  • CD frequency response: 5-20,000 Hz
  • CD signal-to-noise ratio: 105 dB
  • FM sensitivity: 9.3 dBf
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
904
That’s really helpful, thanks! I’ll keep digging and see what I can find online :)
I'm hoping to find someone who might be able to repair this head unit. The faceplate doesn't slide out at all.
243
bjayjr5679
Father of Three
bjayjr5679
Columbus, Ohio
bjayjr5679
audiobaun
    May 19, 2024
    May 19, 2024
