FS blown 18's with tripple 7.5" slugs 1.25" top plate .5" bottom LOCAL PICK UP ONLY
Kryptonitewhite
4 18s
blown
200/ea
local pick up
I have 4 18's that I bottomed out with 3kW per sub, 12kW RMS total for the subs. I never even scortched a coil on them, just ripped the coils from the spiders from over excursion below tuning... tuned to 23Hz had a Jim Jones song that went subsonic with my EQ set to +9dB at 20Hz 25Hz and 32.5Hz //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The 4 18's are Blueprint Audio 1803's, designed by Fi starter/owner, Ascendant Audio owner, RE starter, Blueprint Audio starter Scott Atwell. Scott/Fi will recone them anywhere from single soft spider to 5 stiff spiders for $100/ea, IIRC he said after 5 stiff pack it will cost a little more per spider. They have tripple 7.5" slugs, 1.25" thick top plate, .5" thick bottom plate, about 55-65lbs/each.
If you are willing to pay shipping, I will dig up the wooden crates I received them in and boxes...otherwise local pick up only. Sioux Falls South Dakota 57104
$200 per sub.
$800 all four for now, will negotiate later down the road if theyre not selling...I am in no hurry, I am still working on getting the van running again let alone installing another 350A alt.
voice coils not burnt, rather tripple joint ripped off
1/2" bottom plate
2.5" of slug
1.25" top plate
over 4" of motor
7.5" diameter slugs
Very nice looking! 4" coils?
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif 3" coils, which is why I am selling... I'm looking for 4HPs so I can customize them //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
made a nice weight while PL PRO was curing on the door manifold //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
gap pic
pics taken earlier some may be helpful some redundant sorry
too bad you wont ship //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I will, put you gotta pay..and it's not cheap, they're heavy! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Where you live?
I can sell the motors for $175/ea, $700 for the 4 if that helps
I would be interested in the baskets since I really want to go to 18's, I'm just not sure on that basket design and were these single voice coil. What basket is it and would you be able to give me some dimentions. My zip code is 45822 if you would wanna figure up shipping cost involved. Thanks, Russ
I can do $175 per motor, $700 for all for, you pay shipping.
How much would the baskets go for and would anyone be interested?
those are just standard 6 spoke 18" baskets same ones that Sundown(black),AB,Atomic,DD(black)....and countless other companies use.the one i have has an OD of 18 3/8.they do look like single VC. in that one pic i only see one terminal.
correct, though you can have up to 4 terminals
I was thinking they were the same baskets the shop uses to build the 18's that my buddy can get, but I was'nt sure. Could you get me a total price for the 4 baskets including shipping to 45822, so I can compare prices to see if I can save some cash? Thank you, Russ
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
989
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
5K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
Kryptonitewhite
Kryptonitewhite
soo foo sd
manyhobbies
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
