FS blown 18's with tripple 7.5" slugs 1.25" top plate .5" bottom LOCAL PICK UP ONLY
Kryptonitewhite
4 18s
blown
200/ea
local pick up
I have 4 18's that I bottomed out with 3kW per sub, 12kW RMS total for the subs. I never even scortched a coil on them, just ripped the coils from the spiders from over excursion below tuning... tuned to 23Hz had a Jim Jones song that went subsonic with my EQ set to +9dB at 20Hz 25Hz and 32.5Hz //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The 4 18's are Blueprint Audio 1803's, designed by Fi starter/owner, Ascendant Audio owner, RE starter, Blueprint Audio starter Scott Atwell. Scott/Fi will recone them anywhere from single soft spider to 5 stiff spiders for $100/ea, IIRC he said after 5 stiff pack it will cost a little more per spider. They have tripple 7.5" slugs, 1.25" thick top plate, .5" thick bottom plate, about 55-65lbs/each.
If you are willing to pay shipping, I will dig up the wooden crates I received them in and boxes...otherwise local pick up only. Sioux Falls South Dakota 57104
$200 per sub.
$800 all four for now, will negotiate later down the road if theyre not selling...I am in no hurry, I am still working on getting the van running again let alone installing another 350A alt.
voice coils not burnt, rather tripple joint ripped off
1/2" bottom plate
2.5" of slug
1.25" top plate
over 4" of motor
7.5" diameter slugs
Out of curiosity, how much mechanical excursion are these baskets capable of. I ask because I like to play down around 30hz and below with approx. 2-3000w each sub. Thanks, Russ
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
969
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
Kryptonitewhite
Kryptonitewhite
soo foo sd
manyhobbies
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
