FS: Kenwood KAC-8403
  • 2
fivedollapizza
Kenwood KAC-8403
Specs:
RMS power Output
- 60 x 4
Power at 2 Ohms (Watts x Channels)
- 90 x 4
Bridged power (Watts x Channels)
- 180 x 2
Minimum Impedance Bridged
- 4
Minimum Impedance Unbridged
- 2
Best Frequency Response
- 5-50k Hz
Signal to Noise Ratio
- 100 dB
Tech Specs:
Amplifier Class
- AB
Low-Pass Crossover Frequency
- Rear 50-200 Hz
Low-Pass Slope (dB/octave)
- -18 dB
High-Pass Crossover Frequency
- 50-200 Hz
High-Pass Slope (dB/octave)
- -12 dB
Bass Boost
- Rear 6 dB
Bass Boost Frequency
- 90 Hz
Fan Cooled
- Yes
Fuse Rating
- 40 x 1
Preamp Outputs
- 1 pair
Width (inches)
- 11-9/16
Height (inches)
- 2-9/16
Depth (inches)
- 14-7/8
10/10 functional, i'd give it a 8.5-9/10 cosmetic depending on how picky you are. Has some TINY scratches on it that are only visible when really examining the amp. One larger one on the bottom that will never be seen when mounted. Can get detailed specific pics if anyone's really interested in seeing the tiny ones. Just a bit dusty in the tighter angles. Will be 100% baby wiped down before shipping
$140 shipped. Also have an http://www.caraudio.com/forums/amplifier-classifieds/600112-alpine-pdx4-100-four-channel.html that I'll sell as a package deal for $325 shipped.
Included.
Just have these two cause there really isn't much to show as far as damage or anything like that. If you need specifics, let me know.
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
909
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
373
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
681
fivedollapizza
fivedollapizza
San Antonio TX
swangin68
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
