[FS] SounDrive 17' RCA Cables
  • 5
SounDrive
Pro Seller
www.soundrive.audio
3,114
Lebanon, TN
4 sets of 17' RCA cables - 1 each of red, blue, green, and black
Description/Condition of Item(s):
Brand new
These are premade, so you won't have to wait on build time.
These are fully shielded to prevent noise, and covered by our warranty.
$62 shipped each
Shipping Information:
FedEx
So these should, in theory, kill my alt whine?
As Mylows said, if it's caused by the RCAs then yes it would greatly reduce it, very possibly to the point of not being able to hear it any more. Two local guys eliminated their alt whine with nothing but a direct swap of their RCAs. One guy even swapped from "shielded" Knu cables... That shows me that lots of companies falsely market their shielding.
Still have these sets. I also have a 2 sets of orange that I need to measure - I believe they're 20' but I need to double check.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
877
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
915
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
764
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
857
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
946
SounDrive
Pro Seller
www.soundrive.audio
SounDrive
Lebanon, TN
basswiigee2fix
Decebal
    Jun 10, 2024
