Fusing question
  • 6
Right, so my rear batteries are literally 10 inches from my amps. The cables are run ontop of mdf and carpet so no possible shorts. Would i still need to fuse eventhough a short is literally impossible?
Front batt to rear batt is fused at beginning and end.
anywhere where you have a battery to amp, it should be fused
Just off the battery is best!
John Kuthe
I don't fuse anything. Never had a problem yet. Knock on wood... I'm not spending all this money on good welding wire and then putting some fuse in the way.
Right, so my rear batteries are literally 10 inches from my amps. The cables are run ontop of mdf and carpet so no possible shorts. Would i still need to fuse eventhough a short is literally impossible? Front batt to rear batt is fused at beginning and end.
Fusing will protect if your amp has a catastrophic failure and wants to catch fire. Not really a huge risk, but not really a big investment for some extra safety.
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
299
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
664
Kenyanbasshead
Nairobi
hispls
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
