Fusion amps overrated?
  • 6
Im thinking about ordering one on ebay...its a PowerPlant 2000.1. Heres the specs. What im wondering is if these amps do rated? In a month i can get a P1000 rockford for the same price, but i dont feel like waiting that long. I Searched and couldnt find anyone that had tried one, but it looks like a beast amp. Anyone have one?
Frequency Response (-3dB) - 20hz - 350hz
40A x 3 Fuse Rating
20K Input Impedance
0.2V - 8V Input sensitivity
Max Power Rating (Watts) - 2000
600 Watts RMS x 1 Channel @ 4 Ohms
900 Watts RMS x 1 Channel @ 2 Ohms
1000 Watts RMS x 1 Channel @ 1 Ohm
Well I don't have personal experience with this amp. But my friends do and they so don't put out near the power... At least not without a line driver. they have to turn the gains wide open to get anything out of them. They for sure aren't impressed
So in that case theyre actually better than the rockford p1000 as they do more power then, plus theyre a true class D. I never understood why rockford stuck with the B/D topography for their amps //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Im gonna see what some other people say and then order me one. Will this do fine off 1 run of 4g wire you think? Gonna run it at 2 ohms for a while till i upgrade my alt.
Yes.
Is this a fact? The preouts on my pioneer are 4-6 volt i dont remember which, i hate getting mixed opinions on something //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I don't know the amps personally, but I'd take the opinion of one that says it was tested, over one that says their "friends didn't have it work well".
More likely than anything the friends just didn't know enough. Or thought their subs should be louder than they can really go. Not to mention, where you set the gains at doesn't matter, it's just the reference point to get the right amount of power due to input voltage, which obviously varies based on input voltage. Chances are the line driver just needs to have it's gains cranked up a bit higher.
My friend has a powerplant 2000.1 and it can get his 2 CVT 12" stinky.
I don't think it does 1k at 12v though maybe 800wrms
I was thinking the cost verses the price of a new subwoofer wouldnt be worth the effort. Fusion Audio wasnt a very well made brand of audio in general
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Well I finally had a chance to hook up the us acoustics amp. What a difference. Still playing around with the 13 band equilizer. The h/u put out...
235
451
I Like Waffle
North Carolina
Cameron_B
    May 22, 2024
    May 22, 2024
