Gain set higher on bigger amp?
  • 2
pimpnyou204
Is there a reason why a larger amp would need to be set higher than a smaller to reach the same watts? Granted the first one was 8v and large one 5v but why would it need to be turned up all the way almost to surpass the smaller version at like a 1/4 and near clipping? And no there was no clipping in the larger one. Same ground and settings and all.
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
906
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
pimpnyou204
pimpnyou204
Fort Lauderdale
whitedragon551
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
