Need Amp Suggestions! For 2) T3 T2000 12's
  • 1
bgolightly82
Original plan was to run 2) SS DTR1.2200's but now that I'm actually ready to buy, I'm thinking about changing. Looked at the DD M2's..AQ2200's..Opti4000d..just don't know which way to go. Any suggestions? Limited budget, but not so limited that I'll sacrifice quality. This is for a daily setup so its got to be efficient. Subs are rated for 2k rms, but they're beast, so they'll take a bit more daily i'm sure. Dual 2's. Thanks guys.
11
667
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
972
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
bgolightly82
bgolightly82
Jackson, MI.
bgolightly82
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
