Going active question
corey0928
I have an Alpine 9855, I have the switches in the back switched to 3 way and can't remember what the other one says lol, but I believe its set up to run active.
Now my question is, how do I know what set of RCAs runs the highs and which one is for the mids. I want to run the tweets on the rear channel and the mids on the front or vice versa. I'm guessing the sub still runs the subwoofer stage, but no matter what I set the cross over too it plays the same sounds, or do I need a separate crossover for just the tweets?
Also what does time alignment mean lol
The top pair of RCA's are for Rear/Mid, the middle pair is for Front/High, and the bottom Pair is for Sub/Low.
Time alignment is an adjustable delay. Say you have two speakers, and one speaker is 2 feet away and the other is 3 feet away, the sound from the speaker 2 feet away will reach you before the speaker that is 3 feet away. Using time alignment you would delay the signal to the speaker that is 2 feet away so the sound from both speakers reaches you at the same time.
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
11
Now you're annoying me because you are attacking me personally without addressing anything I've said. Show me a single post I've made that's...
20
4K
corey0928
corey0928
Warren, MI
corey0928
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
