good first setup for less than $500 subs
low key2
looking for a good setup for my mustang for under $500 want the bass loud enough to be heard across the parking lot i can build my own box if i get and idea of what its supposed to look like where to put ports and dimensions just looking for what you guy got
ok then check craigslist thats your best bet as $ 500 is not much.
or check out soundqbed .
also how much room do you have for a box ??
what type of car/truck ?
you need to figure out what space you have for a box. then you can figure out what size sub.
Id go 2 12's cant beat 24 inches of surface area vs 20 from two 10s and I doubt you can fit two 15's in a mustang and who would want to lol. 2 12's is always a good setup
id go single 15 why?
one sub is cheaper than 2.
Means more money for power(amp)
and more money for a custom box.
and more money for better power wire.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
585
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
989
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
906
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
low key2
low key2
minneapolis MN
Jeffdachef
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
