Green light, then red light, now no light
  • 2
c_hayhurst
I have a DEI Audio Mobile Power Series 2504 amp I purchased in 1997.
It has been working fine up until today when I disconnected the battery's negative terminal to link up my Infinity 611a and subs.
When I loosely reconnected the battery's negative terminal and tried to start the car, I got a rapid clicking from the engine telling me to re-seat the terminal. I properly reconnected the battery's negative terminal and...
No power to the DEI or the Infinity. Therefore, no music.
I completely disconnected the Infinity and put everything back the way it was before and checked the DEI's power light. It normally glows a strong green, but glowed a faint red at this point.
I took a voltimeter and checked the battery terminals, power block and DEI's power/ground terminals and everything rated around 55 DC Volts, both while the car was running and when it was shut off.
Then, I let the car idle, and re-checked the volt readings and then I noticed the power light for the DEI is totally out.
All fuses in the amp and on the power line are intact.
Am I missing something or is the amp dead?
It sounds as though the remote wire / radio remote circuit is the problem.
1. Disconnect the remote wire from the amp.
2. Place a jumper wire from the remote input terminal on the amp to the constant + battery input terminal on the amp.
3. If the amp turns on, the problem is a loose remote wire or the radio remote circuit is not providing proper voltage or is curent limited.
It sounds as though the remote wire / radio remote circuit is the problem.1. Disconnect the remote wire from the amp.
Yep, the green light came on strong as ever.
I fiddled with re-seating the remote wire at the amp, and it would make a sporadically strong connection.
Then, the sun went down, so I am MUCH closer to fixing this thanks to your post.
I'd buy a Maxxsonics product in gratitude, but I already have a Brutus I am trying to figure out what to do with //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks again!
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
11
821
I am not well versed in box design, so I do not know outcomes based on over/under sizing. The one thing I do know is that too big of a port will...
5
788
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
c_hayhurst
c_hayhurst
Columbus, Ohio
c_hayhurst
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
