Grounding Issue?
  • 3
Hey everyone. Recently I changed my ground to clean up wires and built a new box. With the new setup my electrical seems to be in HORRIBLE shape. My lights used to dim, and the bass would hit hard. This setup was run at 1 ohm, pulling about 1500 rms. Now, my lights and even amp lights (Hifonics) dims extremely. The bass isnt as loud, but I also tuned my box lower so I expected it some, but not this much. Even running on 4 ohms, 600ish rms, the lights dim bad still. I wonder this to be a grounding issue, or simply just electrical. By alt is charging strong (14.5v) and my battery is a constant 12.9 not running. I havent done big 3 but will when I order lugs. Thanks guys.
NOTE: When I put new ground on, I filed out the lug hole to fit around bolt. Before it would get stuck and twist my wire when I would loosen/tighten it. This reduced the amount of contact metal for the ground.
Post pic of your ground? Sounds like your battery is takin a poop. Go get it load tested at advance auto or something
I will when I get a chance, most likely tonight or tomorrow. And auto zone tested my battery with my alt. which I left out above. It passed all tests.
Ohmmeters measure resistance by measuring voltage and comparing the voltage to a known resistance. They cannot accurately measure resistance on an...
9
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
4
942
RChillin
RChillin
Kansas City
RChillin
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
